Polish the Bridge or no?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=47488
Author:  Bill Higgs [ Sun Mar 20, 2016 5:36 pm ]
Post subject:  Polish the Bridge or no?
Just curious as to how many of you polish your bridges as opposed to just oiling them?
Would also be interested in your techniques.
Bill
Author:  Rod True [ Sun Mar 20, 2016 5:37 pm ]
Post subject:  Re: Polish the Bridge or no?
I usually sand up to 800 grit then buff with a small drill press buffer. Same as I use for my frets and fretboard.
Author:  DennisK [ Sun Mar 20, 2016 5:57 pm ]
Sand up to 600 or 1500 grit and wipe on shellac. Optionally micromesh to full gloss after that.
Author:  tysam [ Sun Mar 20, 2016 6:17 pm ]
I usually sand 400 to 1500, micromesh from 3600 to 8000 and then oil. Most likely overkill but that's what I have always done. :)
Author:  SteveSmith [ Sun Mar 20, 2016 6:33 pm ]
Sand up to around 800 and buff.
Author:  Joe Beaver [ Sun Mar 20, 2016 10:37 pm ]
Polish, buff and then oil for me.
Author:  Mike OMelia [ Sun Mar 20, 2016 10:46 pm ]
What kind of oil?
Author:  johnparchem [ Sun Mar 20, 2016 10:48 pm ]
sand to 800 grit and then refined linseed oil.
Author:  Joe Beaver [ Sun Mar 20, 2016 10:59 pm ]
I use gun stock oil, the kind they sell at Wally World. In a pinch I have used olive oil, seemed to work fine
Author:  David Collins [ Sun Mar 20, 2016 11:09 pm ]
I generally stop by 220 (or a well worn piece of 180), then off to the buffing wheel. I'm sure it depends on what wheels and compounds you use, but with our setup I find no real improvement beyond 220.
Author:  Eric Reid [ Mon Mar 21, 2016 12:25 am ]
Full gloss, pumice pore fill, French polish. Different convention.
Author:  meddlingfool [ Mon Mar 21, 2016 12:53 am ]
All the way to 220, but by hand, which takes more craftsmanship.
Author:  J De Rocher [ Mon Mar 21, 2016 1:01 am ]
For the bridge polishers, does it make a difference to you what wood the bridge is made of? I found that fine sanding/polishing an ebony bridge made it very susceptible to marking. Even a light pass with something like the flat of a finger nail would leave a burnish-like mark. That was irritating so I stopped going above 400. Have any of you had that happen and if so have you figured out a way to deal with it?
Dennis and Eric - Are you talking about bridges for classical guitars?
Author:  Eric Reid [ Mon Mar 21, 2016 2:46 am ]
Guilty as charged. I'm not a fan of ebony, or any high-damping, high-density wood for bridges, and I've had good feedback replacing ebony bridges with Brazilian rosewood on steel strings. But most of my experience is on classicals. For my own guitars, I pay attention to density, conformation, "Q", weight, top deflection, guitar timbre, and yes, bridge "finish".
Author:  Hesh [ Mon Mar 21, 2016 7:05 am ]
OOOO steel wool to get the dirt and finger jam off then off to the buffing wheel followed up by Howard Feed-n-wax. That's if I want a nice deep, dark, polished look on repair instruments.
When I was building micro mesh the crap out of it followed by Howard Feed-n-wax.
I've always loved the way nicer classicals with FPed bridges look - very eloquent!
Author:  RustySP [ Mon Mar 21, 2016 7:45 am ]
Hesh, did you mean to say FPed bridges Sound eloquent or Look elegant?
Author:  Terence Kennedy [ Mon Mar 21, 2016 8:24 am ]
I just go through all the Micromesh grits. I don't buff or oil them. I have also largely gotten away from Ebony. BZ is my favorite .
Author:  DennisK [ Mon Mar 21, 2016 8:44 am ]
Everything. Whenever I try polishing bare wood, it only stays shiny until I touch it and then gets covered in dull fingerprints. Maybe if I let it sit for a few days to form an oxide layer it would be more resilient, but shellac looks better anyway.
First one is straight from scraper to shellac, second is sanded to 1500 grit and then shellacked, and third is the post-shellac micromesh treatment.
Author:  Mike OMelia [ Mon Mar 21, 2016 10:31 pm ]
I'm always interested in interior finishing. I like clean, no shine finish. Bare wood. I've used Port Orford oil for a while now. Does anyone use drying oils?
Author:  Hesh [ Tue Mar 22, 2016 6:31 am ]
Hey Rusty I meant look. You will rarely hear be attempt to qualify tone. :) Been there, done that, got the T-shirt, and won't do it again...:)
Author:  dzsmith [ Tue Mar 22, 2016 8:47 pm ]
Like a dummy, I polished Ebony with compound.
Try as I may, I cannot get all of the compound out of the grain.
Author:  Mike OMelia [ Tue Mar 22, 2016 9:08 pm ]
I know it's a bit off topic, but would anybody recommend drying oils to work the inside of a body?
And, do big box stores sell refined linseed oil or should I go with specialty suppliers?
Author:  Alex Kleon [ Wed Mar 23, 2016 6:30 am ]
Haven't bought any in a number of years, but any hardware or building supply store used to carry it as boiled linseed oil, around these parts, anyways.
Alex
